MOSFETs
Announcing the Wolfspeed 650V Series of SiC MOSFETs
Mar 30, 2020
Designed to withstand the demands of today’s high-powered applications
Wolfspeed is pleased to announce its new 15-mΩ and 60-mΩ 650V Silicon Carbide (SiC) MOSFETs, which incorporate the latest C3M™ Silicon Carbide technology to offer the industry’s lowest on-state resistances and switching losses for higher-efficiency and power-dense solutions. While modern applications have increased demands for both efficiency and performance, Wolfspeed’s 650V SiC MOSFETs are up to the challenge. The family of 650V SiC MOSFETs from Wolfspeed features enable:
High Efficiency
  • Low switching losses
  • Low conduction losses
  • Low reverse-recovery losses
High Power Density
  • Lighter weight
  • Smaller footprint
  • Fewer Components
High efficiency
C3M0060065K vs Competition in a Boost Converter
Wolfspeed 650V MOSFET has both lower switching loss and lower conduction loss
Industry-leading Performance: SiC vs SiC
Normalized RDS(on) vs. Temperature
High power density
Enabling up to 70% higher power density compared to silicon
System Cost Comparison
Reducing total system cost in a 6.6kW bi-directional on-board charger design
Wolfspeed 650V SiC MOSFETs vs. Competing Technologies
When it comes to performance, Wolfspeed Silicon Carbide is in a class of its own. Whether it’s in comparison to traditional silicon solutions or competitors’ Silicon Carbide products, Wolfspeed shines.
650V SiC vs. Silicon
  • 1/2 the conduction losses
  • 4,000% lower body diode reverse-recovery charge
  • 75% lower switching losses, enabling higher efficiencies at higher frequencies
  • Up to 70% greater power density
  • Superior thermal performance
650V SiC vs. GaN on Silicon
  • Over 1/2 the conduction losses
  • Only industry-standard packages
  • Robust gate drive
  • Field-proven reliability
  • Avalanche capability
Wolfspeed 650V SiC vs Competing SiC
  • Industry’s lowest on-resistance increase over operating temperature
  • Low output capacitance
  • High switching frequency
  • Easy to drive
650V MOSFET applications
Wolfspeed’s 650V SiC MOSFETs are built for the demands of today’s cutting-edge technology. From onboard chargers (OBCs) in electric vehicles (EVs) to uninterruptible power supplies (UPSes) and micro-inverters, Wolfspeed’s 650V SiC MOSFETs are rugged enough, reliable enough, and powerful enough for all applications:
Products
No filters selected, showing all 18 products
Products
Gate Charge Total
C3M0025065L
25 mΩ
77 A
111 nC
186 pF
326 W
TOLL
49 A
59 nC
101 pF
164 W
TOLL
39 A
46 nC
72 pF
131 W
TOLL
120 mΩ
21 A
26 nC
45 pF
86 W
TOLL
25 mΩ
80 A
109 nC
178 pF
271 W
TO-263-7 XL
36 A
46 nC
80 pF
136 W
37 A
46 nC
80 pF
150 W
29 A
46 nC
80 pF
150 W
TO-247-3
15 mΩ
120 A
188 nC
289 pF
416 W
15 mΩ
120 A
188 nC
289 pF
416 W
TO-247-3
120 mΩ
22 A
28 nC
45 pF
98 W
120 mΩ
21 A
26 nC
45 pF
86 W
120 mΩ
22 A
28 nC
45 pF
98 W
TO-247-3
49 A
63 nC
101 pF
176 W
49 A
63 nC
101 pF
176 W
TO-247-3
25 mΩ
97 A
112 nC
178 pF
326 W
25 mΩ
97 A
108 nC
178 pF
325 W
TO-247-3
47 A
61 nC
101 pF
147 W
TO-263-7 XL
End of Section
Reference Designs
Explore Wolfspeed’s 650V SiC MOSFETs, companion parts, and reference designs to learn more about how SiC MOSFET technology from Wolfspeed can help you build better products that are up for the demands of today’s modern devices.
Products
No filters selected, showing all 5 products
Products
Dynamic Characterization
Available for Purchase
FM
KIT-CRD-CIL12N-FMC
FM
KIT-CRD-CIL12N-FMA
FM, GM, SpeedVal Kit
CGD1700HB2M-UNA
EVAL-ADUM4146WHB1Z
EVAL-ADUM4146WHB1Z
Si823H-ACWA-KIT
End of Section
Low Voltage Industrial Drives
