Power Modules
Announcing the Newest Additions to the Wolfspeed WolfPACK™ Power Module Family
Nov 06, 2023
All Wolfspeed WolfPACKTM silicon carbide power modules are now available with the option of pre-applied thermal interface material (TIM)
Wolfspeed WolfPACK™ SiC Power Modules Family
The Wolfspeed WolfPACK power module family is designed to give engineers choice and flexibility when working on power electronics applications greater than 10 kW.
In addition to half-bridge and six-pack topologies, WolfPACK modules are now available in full-bridge configurations—all with the option for pre-applied Honeywell™ PTM6000 Series TIM.
Selecting pre-applied TIM can reduce assembly cost and complexity, while improving reliability and performance. Compared to standard grease solutions, WolfPACK modules with pre-applied TIM can reduce the junction temperature by 40°C under the same conditions or increase current capability by 60% due to the reduction in thermal resistance.
All WolfPACK modules are designed to provide clean, reliable power for energy conversion systems. By leveraging more than 35 years of vertically integrated industry experience, Wolfspeed ensures that these modules offer low losses in a package that lends itself to fast design implementation, scalability, long term design support, and lower assembly overhead.
Ready to get started? Request your sample or buy online now.
WolfPACK modules are highly flexible, making them well-suited to a wide variety of applications with power levels from 10 to 150+ kW, including:
  • Leading silicon carbide MOSFET technology in an industry standard form factor
  • Highest current rated topologies versus market equivalents
  • Built in NTC
  • Press fit connections
  • Ease of layout and assembly
  • System scalability and reliability
  • Discrete design consolidated into a single package
  • Increased power density / reduced system size
Featured Products
Products
No filters selected, showing all 24 products
Products
Configuration
Maximum Junction Temperature
Module Size
CAB006M12GM3
GM
Half-Bridge
200 A
6 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
GM
Half Bridge (AlN substrate)
200 A
6 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
GM
Half-Bridge
200 A
6 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
GM
200 A
6 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
GM
181 A
8 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
GM
Half-Bridge
160 A
8 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
GM
Half-Bridge
160 A
8 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
GM
181 A
8 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
FM
Half-Bridge
117 A
11 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
FM
Half-Bridge
117 A
11 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
GM
Half-Bridge
141 A
11 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
GM
Half-Bridge
141 A
11 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
FM
Half-Bridge
84 A
16 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
FM
Half-Bridge
84 A
16 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
GM
Six-pack (three-phase)
50 A
16 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
GM
50 A
16 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
FM
30 A
21 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
FM
Full-Bridge
48 A
21 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
FM
30 A
21 mΩ
150 °C
62.8 mm x 33.8 mm
FM
Full-Bridge
48 A
21 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
FM
30 A
32 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
FM
Full-Bridge
37 A
32 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
FM
30 A
32 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
FM
Full-Bridge
37 A
32 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
Evaluation Kits
Perform characterization in your own lab using Wolfspeed’s clamped inductive load (CIL) boards to better understand the capability of our silicon carbide modules under your application conditions.
Products
No filters selected, showing all 5 products
Products - Filter By
Products
Form
Evaluation Tool
FM
KIT-CRD-CIL12N-FMA
Evaluation Tool
FM
KIT-CRD-CIL12N-FMC
Evaluation Tool
GM
KIT-CRD-CIL12N-GMA
Evaluation Tool
FM
KIT-CRD-CIL12N-FMB
Transceiver
CGD12HB00D
Reference Designs
Get started faster with time-saving reference designs for inverters, motors drives, and active front ends.
Products
No filters selected, showing all 2 products
Products
AC to DC, DC to AC
Passive Rectifier and Three-Phase, 2-Level
7.5kW
Module
FM
DC to AC
25kW
Module
FM
Gate Driver Boards
Evaluate compatible gate drive solutions from our partners to find the right fit.
Products
No filters selected, showing all 3 products
Products
Platform
Gate Driver
Output Channels
Gate Power
Miller Clamp
Short-Circuit Protection
Temperature Feedback
Interface Tool
Si823H-AAWA-KIT
FM, GM
Skyworks
2
1W
No
No
FM, GM, SpeedVal Kit
Analog Devices
2
2W
2W
Download application notes for expert guidance and considerations when implementing Wolfspeed products.
  • CPWR-AN48 KIT-CRD-CIL12N-GMA Application Note
  • CPWR-AN42 FM3 TIM Application Note
Analyzing Transient Behavior Using a Double Pulse Test Simulation in LTspice
See how Wolfspeed LTspice models can make designing with silicon carbide in power electronics systems more efficient, cost-effective, and accurate. Get started optimizing your system design, without the need for physical samples or test kits.
View Now  Videos
