Discrete Silicon Carbide Schottky Diodes
Further reduce conduction losses with ultra-low voltage drop Schottky diodes in power rectifier applications, or any circuit that requires protection from reverse current.
Featured Application Notes
Products
No filters selected, showing all 86 products
Product SKU | Buy Online | Request Sample | Data Sheet | CAD Model | Status | Blocking Voltage | Current Rating | Forward Voltage(VF(type)) | Maximum Continuous Current (IF) | Package | Qualification |
Active | 600 V | 1 A | 1.6 V | 1 A | TO-252-2 | Industrial | |||||
Active | 600 V | 1 A | 1.6 V | 1 A | TO-220-2 | Industrial | |||||
Active | 600 V | 2 A | 1.5 V | 2 A | TO-252-2 | Industrial | |||||
Active | 600 V | 2 A | 1.5 V | 2 A | TO-220-F2 Full | Industrial | |||||
Active | 600 V | 2 A | 1.5 V | 2 A | TO-220-2 | Industrial | |||||
Active | 600 V | 3 A | 1.5 V | 3 A | TO-252-2 | Industrial | |||||
Active | 600 V | 3 A | 1.5 V | 3 A | TO-220-F2 Full | Industrial | |||||
Active | 600 V | 3 A | 1.5 V | 3 A | TO-220-2 | Industrial | |||||
Active | 600 V | 4 A | 1.5 V | 4 A | TO-252-2 | Industrial | |||||
Active | 600 V | 4 A | 1.5 V | 4 A | TO-220-F2 Full | Industrial | |||||
Active | 600 V | 4 A | 1.5 V | 4 A | TO-220-2 | Industrial | |||||
Active | 600 V | 6 A | 1.5 V | 6 A | TO-263-2 | Industrial | |||||
Active | 600 V | 6 A | 1.5 V | 6 A | TO-220-F2 Full | Industrial | |||||
Active | 600 V | 6 A | 1.5 V | 6 A | TO-220-2 | Industrial | |||||
Active | 600 V | 8 A | 1.5 V | 8 A | TO-263-2 | Industrial | |||||
Active | 600 V | 8 A | 1.5 V | 8 A | TO-220-2 | Industrial | |||||
Active | 600 V | 10 A | 1.5 V | 10 A | TO-263-2 | Industrial | |||||
Active | 600 V | 10 A | 1.5 V | 10 A | TO-220-2 | Industrial | |||||
Active | 600 V | 16 A | 1.5 V per leg | 16 A | TO-247-3 | Industrial | |||||
Active | 600 V | 20 A | 1.5 per leg | 20 A | TO-247-3 | Industrial | |||||
Active | 650 V | 2 A | 1.5 V | 2 A | TO-252-2 | Industrial | |||||
Active | 650 V | 3 A | 1.5 V | 3 A | TO-252-2 | Industrial | |||||
Active | 650 V | 4 A | 1.5 V | 4 A | TO-252-2 | Industrial | |||||
Active | 650 V | 4 A | 1.5 V | 4 A | TO-220-2 | Industrial | |||||
Active | 650 V | 4 A | 1.27 V | 4 A | TO-252-2 | Industrial | |||||
Active | 650 V | 4 A | 1.27 V | 4 A | TO-220-2 | Industrial | |||||
Active | 650 V | 6 A | 1.27 V | 6 A | QFN 8x8 | Industrial | |||||
Active | 650 V | 6 A | 1.27 V | 6 A | TO-263-2 | Industrial | |||||
Active | 650 V | 6 A | 1.5 V | 6 A | TO-252-2 | Industrial | |||||
Active | 650 V | 6 A | 1.5 V | 6 A | TO-220-2 | Industrial | |||||
Active | 650 V | 6 A | 1.27 V | 6 A | TO-252-2 | Industrial | |||||
Active | 650 V | 6 A | 1.27 V | 6 A | TO-220-2 | Industrial | |||||
Active | 650 V | 6 A | 1.5 V | 6 A | TO-220-2 Isolated | Industrial | |||||
Active | 650 V | 8 A | 1.27 V | 8 A | QFN 8x8 | Industrial | |||||
Active | 650 V | 8 A | 1.27 V | 8 A | TO-263-2 | Industrial | |||||
Active | 650 V | 8 A | 1.5 V | 8 A | TO-252-2 | Industrial | |||||
Active | 650 V | 8 A | 1.5 V | 8 A | TO-220-2 | Industrial | |||||
Active | 650 V | 8 A | 1.27 V | 8 A | TO-252-2 | Industrial | |||||
Active | 650 V | 8 A | 1.27 V | 8 A | TO-220-2 | Industrial | |||||
Active | 650 V | 8 A | 1.5 V | 8 A | TO-220-2 Isolated | Industrial | |||||
Active | 650 V | 10 A | 1.27 V | 10 A | QFN 8x8 | Industrial | |||||
Active | 650 V | 10 A | 1.27 V | 10 A | TO-263-2 | Industrial | |||||
Active | 650 V | 10 A | 1.5 V | 10 A | TO-252-2 | Industrial | |||||
Active | 650 V | 10 A | 1.5 V | 10 A | TO-220-2 | Industrial | |||||
Active | 650 V | 10 A | 1.27 V | 10 A | TO-252-2 | Industrial | |||||
Active | 650 V | 10 A | 1.27 V | 10 A | TO-220-2 | Industrial | |||||
Active | 650 V | 10 A | 1.5 V | 10 A | TO-220-2 Isolated | Industrial | |||||
Active | 650 V | 12 A | 1.5 V | 12 A | TO-220-2 | Industrial | |||||
Active | 650 V | 16 A | 1.3 V | 53 A | TO-247-2 | Industrial | |||||
Active | 650 V | 16 A | 1.5 V | 16 A | TO-247-3 | Industrial | |||||
Active | 650 V | 16 A | 1.5 V per leg | 16 A | TO-247-3 | Industrial | |||||
Active | 650 V | 16 A | 1.27 V | 16 A | TO-247-3 | Industrial | |||||
Active | 650 V | 16 A | 1.5 V | 16 A | TO-220-2 | Industrial | |||||
Active | 650 V | 20 A | 1.27 V | 20 A | TO-247-3 | Industrial | |||||
Active | 650 V | 20 A | 1.27 V | 20 A | TO-263-2 | Industrial | |||||
Active | 650 V | 20 A | 1.27 V | 20 A | TO-247-2 | Industrial | |||||
Active | 650 V | 20 A | 1.27 V | 21 A | TO-220-2 | Industrial | |||||
Active | 650 V | 20 A | 1.5 V per leg | 20 A | TO-247-3 | Industrial | |||||
Active | 650 V | 30 A | 1.35 V | 88 A | TO-247-2 | Industrial | |||||
Active | 650 V | 30 A | 1.5 V | 30 A | TO-247-3 | Industrial | |||||
Active | 650 V | 50 A | 1.3 V | 50 A | TO-247-2 | Industrial | |||||
Active | 650 V | 50 A | 1.3 V | 50 A | TO-247-3 | Industrial | |||||
Active | 1200 V | 2 A | 1.4 V | 2 A | TO-252-2 | Industrial | |||||
Active | 1200 V | 2 A | 1.4 V | 2 A | TO-220-2 | Industrial | |||||
Active | 1200 V | 5 A | 1.4 V | 5 A | TO-252-2 | Industrial | |||||
Active | 1200 V | 5 A | 1.4 V | 5 A | TO-220-2 | Industrial | |||||
Active | 1200 V | 8 A | 1.5 V | 8 A | TO-252-2 | Industrial | |||||
Active | 1200 V | 8 A | 1.5 V | 8 A | TO-220-2 | Industrial | |||||
Active | 1200 V | 10 A | 1.4 V | 10 A | TO-247-2 | Industrial | |||||
Active | 1200 V | 10 A | 1.5 V | 10 A | TO-252-2 | Industrial | |||||
Active | 1200 V | 10 A | 1.4 V | 10 A | TO-247-3 | Industrial | |||||
Active | 1200 V | 10 A | 1.5 V | 10 A | TO-220-2 | Industrial | |||||
Active | 1200 V | 15 A | 1.5 V | 15 A | TO-247-2 | Industrial | |||||
Active | 1200 V | 15 A | 1.5 V | 15 A | TO-247-3 | Industrial | |||||
Active | 1200 V | 15 A | 1.6 V | 15 A | TO-220-2 | Industrial | |||||
Active | 1200 V | 20 A | 1.5 V | 20 A | TO-247-2 | Industrial | |||||
Active | 1200 V | 20 A | 1.5 V per leg | 20 A | TO-247-3 | Industrial | |||||
Active | 1200 V | 20 A | 1.5 V | 20 A | TO-220-2 | Industrial | |||||
Active | 1200 V | 30 A | 1.5 V | 30 A | TO-247-2 | Industrial | |||||
Active | 1200 V | 30 A | 1.6 V per leg | 30 A | TO-247-3 | Industrial | |||||
Active | 1200 V | 40 A | 1.5 V | 40 A | TO-247-2 | Industrial | |||||
Active | 1200 V | 40 A | 1.5 V per leg | 40 A | TO-247-3 | Industrial | |||||
Active | 1700 V | 5 A | 1.5 V | 5 A | TO-247-2 | Industrial | |||||
Active | 1700 V | 10 A | 1.5 V | 10 A | TO-247-2 | Industrial | |||||
Active | 1700 V | 25 A | 1.5 V | 25 A | TO-247-2 | Industrial |
Explore The Options
- Technical & Sales Documents
- Tools & Support
- Compliance
14 Documents Available
Document Type | Document Name | Last Updated |
Application Notes | 02/2025 | |
Application Notes | 07/2024 | |
Application Notes | 01/2024 | |
Application Notes | 12/2023 | |
Application Notes | 08/2023 | |
Application Notes | 01/2023 | |
Application Notes | 09/2022 | |
Application Notes | 02/2022 | |
Application Notes | 09/2015 | |
Product Catalog | 01/2025 | |
Sales Terms | 04/2025 | |
Packing & Shipping | Power Product Packing & Shipping Reference Guide This document details the production packaging details including container type, quantity, MOQ, and dimensions as well as the moisture sensitivity level (MSL) for discrete SiC Schottky Diodes and MOSFETs.
| 03/2025 |
