    Renewable Energy
    Energy Storage Systems
    Wolfspeed Silicon Carbide is capable of incredible reliability and efficiency within battery-based energy storage systems, meaning power is always available even when the sun sets.
    • Block Diagrams
    • Block Diagrams
    Energy Storage Systems Enable a Secure Energy Future
    One of the biggest challenges facing the renewable industry is how to manage supply vs demand, as power generated by solar and wind systems can fluctuate considerably depending on environmental conditions and time of day. Battery-based Energy Storage Systems (ESS) are one way that system designers can address this challenge and create a reliable energy infrastructure at the residential, commercial, industrial and utility levels.
    Wolfspeed Silicon Carbide MOSFETs, Schottky diodes and power modules are the gold-standard for energy storage systems, creating systems that are more efficient and power dense, have simpler circuit topologies that reduce overall cost and size, all while meeting emerging efficiency standards.
    Illustrated diagram showing how solar panels are used to charge power grids, EV chargers, industrial and residential applications.
    Close up product image of the Wolfspeed WolfPACK™ power modules
    Wolfspeed WolfPACK® Silicon Carbide Power Modules provide an excellent solution for fast design implementation, scalability, and lower assembly overhead.
    Residential and Commercial Energy Storage Solutions
    Solar photovoltaic and wind energy storage systems have multiple power stages that can benefit from Wolfspeed Silicon Carbide MOSFETs, Schottky diodes and power modules, including the Wolfspeed WolfPACK® family of devices. Whether it is a single-phase residential system (5-15 kW) ore three-phase commercial system (30-100 kW), the architecture and power circuit topologies are similar and can be scaled according to power level.
    At the residential and commercial level, energy storage systems save excess power generated during peak times for the building it is tied to. Using Wolfspeed Silicon Carbide in a residential or light commercial buck/boost battery interface circuit can improve charge and discharge efficiency while reducing system cost and size.
    Three 1200V SiC MOSFETs arranged in a horizontal row.
    Wolfspeed offers the broadest portfolio of 1200 V SiC MOSFETs in the industry. These MOSFETs are optimized for use in high power applications and based on 3rd generation technology.
    Utility-Scale Energy Storage Solutions
    Larger industrial and utility-scale energy storage systems utilize massive battery storage systems that operate before the meter, storing enough power for large factories or entire utility grids. These large-scale ESS can also benefit from Wolfspeed Silicon Carbide in the buck/boost circuit. Currently, using Wolfspeed’s 1200 V MOSFETs and Schottky diodes in a three-level configuration or WolfPACK®  Six-Pack Modules provides an ideal combination of efficiency and ease of design along with the highest system power density. New 1500 V photovoltaic solar systems are delivering higher voltage to energy storage systems.
    Accelerate your solar system design process with SpeedFit® Design Simulator
    Watch as Wolfspeed's Zan Huang demonstrates using the SpeedFit® Design Simulator to simulate a solar MPPT Boost Converter and see how you can achieve high efficiency and power density in solar systems even under elevated temperatures.
    When You Need Power You Can Rely on, Choose Wolfspeed
    Alternative energy systems are an alternative only when they can be counted on, which is why Wolfspeed is a great choice. Wolfspeed SiC’s robust performance has proven its value time and again, with billions of field hours for our most popular SiC components.
    Up To
    30%
    Lower Losses
    Up To
    50%
    Higher Power Density
    Up To
    15%
    System Cost Savings
    Block Diagrams
    • This T-type topology for a 800 V system utilizes 1200 V MOSFETs in series or 1200 V half-bridge power modules coupled with 650V or 750 V MOSFETs to achieve reduced overall system losses.
      Power Solar T Type inverter
      Wolfspeed Silicon Carbide (SiC) MOSFETs enable higher switching frequencies and reduce the size of components like inductors, capacitors, filters & transformers.
      Composite image of the three 1200V packages used for Wolfspeed's Discrete Silicon Carbide MOSFETs
      View Products
      650 V / 750 V Series for Side Switch
      Our Silicon Carbide MOSFETs replace silicon devices to enable lower switching and conduction losses with higher blocking voltages and avalanche capability.
      Composite image of the four 650V packages used for Wolfspeed's Discrete Silicon Carbide MOSFETs
      View Products
      750 V Discrete Silicon Carbide MOSFETs
      Composite image of the front and back sides of a Wolfspeed discrete Silicon Carbide (SiC) MOSFET in a TO-247-4 LP package
      View Products
      Wolfspeed WolfPACK® 1200 V Half-Bridge Family
      Wolfspeed WolfPACK® modules are a great choice for designers who want to increase efficiency and power density in a compact, industry standard footprint.
      Product shots of the WolfPACK SiC Power Modules in the FM3 & GM3 packages.
      View Products
      Wolfspeed WolfPACK® 1200 V T-Type Modules
      View Products
    • Innovative 2300 V modules utilize 200 mm silicon carbide technology to enable simplified system architectures, while providing industry-leading switching performance, improved device and system durability.
      Six-Switches-2-level-inverter
      Wolfpack 2.3 KV Half Bridge Modules for 1500 V System
      View the Products
      1200 V Series for 950 V/1000 V system
      View the Products
    • This approach uses 650 V or 750 V MOSFETs for single-phase systems and 1200 V MOSFETs for three-phase systems for improved battery charging.
      Bi-directional-DC-DC-Battery-48v-Charger
      650 V/750 V Series for Single Phase
      View the Products
      1200V Series for Three Phases
      Angled product photo of the front and back of the TO-247-3 package used for Wolfspeed's Discrete Silicon Carbide MOSFETs.
      View the Products
    • This simplified boost converter couples 650 V or 750 V MOSFETs for single-phase system or 1200 V MOSFETs for three-phase systems with complimentary diodes for a complete silicon carbide boost converter solution
      2-level-Boost-Converter
      Silicon Carbide Schottky Diodes
      C6D 650 V Series for Single-Phase
      Wolfspeed’s 650 V Silicon Carbide (SiC) Schottky diode technology is optimized for high-performance power electronics applications including server power supplies, electric vehicle EV fast charging systems, energy storage systems, solar (PV) inverters, consumer electronics, and more.
      View the Products
      C4D 1200 V for Three-Phase
      Wolfspeed has the broadest portfolio of Silicon Carbide (SiC) Schottky diodes, with more than twelve trillion field hours, lowest FIT rate, and 30+ years of experience in Silicon Carbide, combined with the fastest delivery times.
      Image that includes both the front and back of the TO-252-2 package used for Wolfspeed's discrete Silicon Carbide power devices including SiC MOSFETs and Schottky diodes.
      View the Products
      View the Products
      1200 V Series for Three-Phase
      View the Products
    • This 2-level, three-phase inverter provides a simplified power topology for minimal component count.
      2-level-three-phase-inverter-renewable-energy
      Wolfpack 1.2KV Half Bridge Modules for 1000 V System
      View the Products
      Wolfpack 1.2KV Six-Pack Modules for 1000 V System
      View the Products
      View the Products
    Featured Products
    View Now Webinars
    Revolutionizing Power Electronics with Silicon Carbide to Pioneer Sustainable Solutions
