    • 62 mm BM3 Silicon Carbide Half-Bridge Power Modules
    New BM3 Half-Bridge Module with Schottky Diodes for Higher Frequency Industrial Applications
    Wolfspeed’s BM3 power module platform provides the system benefits of Silicon Carbide (SiC) while maintaining the robust, industry-standard 62 mm module package. The internal design of Wolfspeed’s 62 mm BM3 package enables high speed Silicon Carbide switching benefits and increased system efficiency, due to the low-inductance layout. The BM3 platform is a perfect fit for high frequency industrial applications such as induction heating, rail and traction, motor drives, and EV charging infrastructures.
    Angled product photo of the white 62 mm half-bridge power module for Wolfspeed. Its form factor is used for both BM2 and BM3 families.
    No filters selected, showing all 26 products
    Configuration
    Module Size
    Pre-Applied TIM
    WAS175M12BM3
    Purchase WAS175M12BM3
    B
    Half-Bridge
    175 A
    8 mΩ
    150 °C
    105 x 62 x 31 mm
    No
    Industrial + HV-H3TRB
    CAS175M12BM3
    Purchase CAS175M12BM3
    B
    Half-Bridge
    175 A
    8 mΩ
    150 °C
    105 x 62 x 31 mm
    No
    HAS175M12BM3
    Purchase HAS175M12BM3
    B
    Half-Bridge
    175 A
    8 mΩ
    150 °C
    105 x 62 x 31 mm
    No
    Product shot of Wolfspeed's HAS BM3 Half-bridge SiC power module package
    CAS175M12BM3T
    Purchase CAS175M12BM3T
    B
    Half-Bridge
    175 A
    8 mΩ
    150 °C
    105 x 62 x 31 mm
    HAS175M12BM3T
    Purchase HAS175M12BM3T
    B
    Half-Bridge
    175 A
    8 mΩ
    150 °C
    105 x 62 x 31 mm
    WAS175M12BM3T
    Purchase WAS175M12BM3T
    B
    Half-Bridge
    175 A
    8 mΩ
    150 °C
    105 x 62 x 31 mm
    CAS310M17BM3
    Purchase CAS310M17BM3
    B
    Half-Bridge
    1700 V
    310 A
    4.29 mΩ
    150 °C
    105 x 62 x 31 mm
    No
    WAS310M17BM3
    Purchase WAS310M17BM3
    B
    Half-Bridge
    1700 V
    310 A
    4.29 mΩ
    150 °C
    105 x 62 x 31 mm
    No
    HAS310M17BM3
    Purchase HAS310M17BM3
    B
    Half-Bridge
    1700 V
    310 A
    4.29 mΩ
    150 °C
    105 x 62 x 31 mm
    No
    CAS310M17BM3T
    Purchase CAS310M17BM3T
    B
    Half-Bridge
    1700 V
    310 A
    4.29 mΩ
    150 °C
    105 x 62 x 31 mm
    HAS310M17BM3T
    Purchase HAS310M17BM3T
    B
    Half-Bridge
    1700 V
    310 A
    4.29 mΩ
    150 °C
    105 x 62 x 31 mm
    WAS310M17BM3T
    Purchase WAS310M17BM3T
    B
    Half-Bridge
    1700 V
    310 A
    4.29 mΩ
    150 °C
    105 x 62 x 31 mm
    WAS350M12BM3
    Purchase WAS350M12BM3
    B
    Half-Bridge
    350 A
    4 mΩ
    150 °C
    105 x 62 x 31 mm
    No
    CAS350M12BM3
    Purchase CAS350M12BM3
    B
    Half-Bridge
    350 A
    4 mΩ
    150 °C
    105 x 62 x 31 mm
    No
    HAS350M12BM3
    Purchase HAS350M12BM3
    B
    Half-Bridge
    350 A
    4 mΩ
    150 °C
    105 x 62 x 31 mm
    No
    CAS350M12BM3T
    Purchase CAS350M12BM3T
    B
    Half-Bridge
    350 A
    4 mΩ
    150 °C
    105 x 62 x 31 mm
    HAS350M12BM3T
    Purchase HAS350M12BM3T
    B
    Half-Bridge
    350 A
    4 mΩ
    150 °C
    105 x 62 x 31 mm
    WAS350M12BM3T
    Purchase WAS350M12BM3T
    B
    Half-Bridge
    350 A
    4 mΩ
    150 °C
    105 x 62 x 31 mm
    CAB530M12BM3
    Purchase CAB530M12BM3
    B
    Half-Bridge
    530 A
    2.6 mΩ
    150 °C
    105 x 62 x 31 mm
    No
    WAS530M12BM3
    Purchase WAS530M12BM3
    B
    Half-Bridge
    530 A
    2.6 mΩ
    150 °C
    105 x 62 x 31 mm
    No
    CAS530M12BM3
    Purchase CAS530M12BM3
    B
    Half-Bridge
    530 A
    2.6 mΩ
    150 °C
    105 x 62 x 31 mm
    No
    HAS530M12BM3
    Purchase HAS530M12BM3
    B
    Half-Bridge
    530 A
    2.67 mΩ
    150 °C
    105 x 62 x 31 mm
    No
    CAB530M12BM3T
    Purchase CAB530M12BM3T
    B
    Half-Bridge
    530 A
    2.6 mΩ
    150 °C
    105 x 62 x 31 mm
    CAS530M12BM3T
    Purchase CAS530M12BM3T
    B
    Half-Bridge
    530 A
    2.6 mΩ
    150 °C
    105 x 62 x 31 mm
    HAS530M12BM3T
    Purchase HAS530M12BM3T
    B
    Half-Bridge
    530 A
    2.67 mΩ
    150 °C
    105 x 62 x 31 mm
    WAS530M12BM3T
    Purchase WAS530M12BM3T
    B
    Half-Bridge
    530 A
    2.6 mΩ
    150 °C
    105 x 62 x 31 mm
    Designer’s Guide for SiC – A Paradigm Shift in the Way Energy is Generated, Stored, Converted, and Used
    Register Now Webinars
    • Industry-Leading; Reliable Silicon Carbide MOSFET Technology in Robust; Well-Established 62mm Form Factor
    • Strong Thermal Performance + Material Selections Optimized for Industrial & Harsh Environment Applications
    • Low-Inductance Design (10 – 15 nH) for Fast Switching with Low Power Losses
    • MOSFET Die and Selected Modules Qualified to HV-H3TRB
    • Broad Portfolio of Current and Voltage Ratings Available to Fit Diverse Industrial Application Requirements
    • Fast Time to Market with Minimal Development Required for Transition from 62 mm IGBT Packages
    • Reduced Cooling Requirements & Overall System Cost
    • Optimized Internal Layout for Low Power Losses & Minimal Overshoot for Maximum Voltage Utilization
    • Induction Heating
    • Motor Drives
    • Energy Generation / Smart Grids / Smart Energy
    • Railway
    • EV Fast Charging
    • UPS and SMPS
    PRD-06983: BM Module Platform Mounting User Guide
    PRD-07845: Power Module Baseplate Capacitance and Electromagnetic Compatibility
    41 Documents Available
    CAB530M12BM3 (PDF)
    08/2025
    HAS350M12BM3 (PDF)
    HAS175M12BM3 (PDF)
    WAS310M17BM3 (PDF)
    WAS530M12BM3 (PDF)
    WAS350M12BM3 (PDF)
    WAS175M12BM3 (PDF)
    CAS530M12BM3 (PDF)
    CAS350M12BM3 (PDF)
    CAS175M12BM3 (PDF)
    HAS310M17BM3 (PDF)
    HAS530M12BM3 (PDF)
    WAB300M12BM3 (PDF)
    WAB400M12BM3 (PDF)
    PRD-06983: BM Module Platform Mounting User Guide (PDF)
    Wolfspeed BM3 Power Modules Product Brief (PDF)
    02/2023
