XM3 Half-Bridge Power Module Family
Half-Bridge Power Module Designed for Silicon Carbide to Enable High Power Density
Wolfspeed has developed the XM3 power module platform to maximize the benefits of silicon carbide, while keeping the module and system design robust, simple, and cost effective. With half the weight and volume of a standard 62 mm module, the XM3 power module maximizes power density while minimizing loop inductance and enabling simple power bussing. The optimized packaging enables 175°C continuous junction operation, with a high reliability Silicon Nitride (Si3N4) power substrate to ensure mechanical robustness under extreme conditions. The XM3 is a perfect fit for demanding applications such as traction drives, DC fast chargers, universal power supplies and automotive testing equipment.
XM3 Half-Bridge Power Module Family - Filter By
Configuration
Module Size
CAB320M17XM3
XM
Half-Bridge
1700 V
320 A
3.5 mΩ
80 x 53 x 19 mm
XM
Half-Bridge
400 A
4 mΩ
Gen 3 MOS
80 x 53 x 19 mm
XM
Half-Bridge
425 A
3.2 mΩ
Gen 3 MOS
80 x 53 x 19 mm
XM
Half-Bridge
450 A
2.6 mΩ
Gen 3 MOS
80 x 53 x 19 mm
XM
Half-Bridge
450 A
2.6 mΩ
Gen 3 MOS
80 x 53 x 19 mm
CAB525F12XM3
XM
Half-Bridge
525 A
2.6 mΩ
80 x 53 x 23.3 mm
End of Section
  • High Temperature (175 °C) Operation
  • Low Inductance (6.7 nH) Design
  • Utilizes Latest 3rd Generation Silicon Carbide MOSFETS
  • Integrated Temperature Sensor and Kelvin-Drain Connection
  • Silicon Nitride Ceramic Substrate and Copper Baseplate
  • Power Dense Footprint Enables Compact Systems
  • Offset Terminal Layout Simplifies Bus Bar Design and Reduces System Stray Inductance
  • Low Inductance Design Enables Fast Switching to Reduce Dynamic Losses
  • SiN AMB Substrate and High Reliability Solders Enhance Lifetime
  • Direct Gate Driver Mating Enables Compact Design with Low Inductance
  • Traction Drives
  • Motor Drives
  • UPS
  • EV Chargers
  • Industrial Automation & Testing
  • Power Supplies
  • More Electric Aircraft and eVTOL
  • Energy Generation/Smart Grids/Smart Energy
Data Sheets09/2024
Data Sheets06/2024
Data Sheets06/2024
Data Sheets06/2024
Data Sheets06/2024
Data Sheets06/2024
User Guide03/2025
User Guide01/2025
User Guide01/2024
User Guide01/2024
User Guide12/2023
User Guide10/2023
User Guide09/2023
Application Notes01/2025
Application Notes07/2024
Application Notes03/2024
Application Notes01/2024
Application Notes11/2023
Application Notes08/2023
Application Notes01/2023
Videos11/2023
White Papers11/2024
Articles and Papers12/2022
Product Catalog01/2025
Sales Sheets & Flyers01/2024
Sales Sheets & Flyers06/2022
Sales Sheets & Flyers04/2022
Sales Sheets & Flyers03/2022
Sales Terms12/2021
Continue Reading  Webinars
