Power Modules
Apr 01, 2024
Press fit pins allow for a low resistance, high reliability solderless electrical connection between the power module and power circuit board (PCB).
In this video, you’ll see the step-by-step press-in process, including fixturing requirements and connection quality standards, for inserting Wolfspeed WolfPACK silicon carbide power modules into a PCB.
The process is identical for all WolfPACK modules, including industry standard FM and GM footprints now available in half-bridge, six-pack, and full-bridge configurations with the option of pre-applied thermal interface material (TIM).
If you’re ready to get started, you can purchase or request a sample now.
Learn more in the Wolfspeed WolfPACK Mounting Instructions & PCB Requirements user guide or join the Power Applications Forum to start a new discussion with the Wolfspeed technical community.
Low Voltage Industrial Drives
